RE: FLy Eagle Jet Models
Well two years later the F-16 flew.And the wheels and doors worked after new air cylinders were installed and valves and tubeing.The plane is the 1/8 first verson with a p-70 in it.The plane came out at 21.1 lbs. dry.The cg is at 152mm back and the throughs were what FE.recommended.The flight lasted 5 min with fuel almost full in the 2 main tanks the first 16 oz. over the intake is used first.I bent the front pin on landing and drilled it out to a 1/4 pin size.The plane is ready to go again.
