Pull-Pull Elevator on DP Ultimate - am I missing something
you're right man. that only adjusts TENSION on the cable-not the throw geometry. Gotta go outboard on the horn, if no other adjustment from the transmitter is available. I wouldn't try going TOWARD the controll surface horn-might cause flutter.
