RCU Forums - View Single Post - Pull-Pull Elevator on DP Ultimate - am I missing something
Old 06-29-2003 | 02:01 PM
splais
My Feedback: (25)
Default Pull-Pull Elevator on DP Ultimate - am I missing something
Robo, yes, but if you have different tension in the upper and lower cable you are not really changing the throw. You are just allowing slop in the looser cable which gives a false since of changing throw. It's kind of a technical point. And what you say probably works. But from a purely technical point and the "I know I did it" point of view, I think it's a compromise.
I have given this problem a geat deal of thought and come to the conclusion that a single servo, split elevator, pull-pull is not the best system for the simple point that the hinge line on both sides must be exactly on plane for the throws to be identical. When I re-hinged, it threw the two sides off.
