RE: Picture Tutorial: Swapping out your 10X / 12X batteries
Hi Chad:
I put both of your Eneloops into old 10X cases. A very tight fit indeed, as was getting the native 12X pack into it's case after I took it out to remove the temp sensor.
The side opposite the screws, with the two plastic tongues and slots kept popping open. My solution was to tape that side shut after I got the circuit board and packs properly seated with Scotch Brand Gloss Finish MultiTask Tape that you can buy almost anywhere. Used longitudinally across the joint of the cassette, it has essentially zero stretch.
Finally I close the pack down with the screws.
