Looks good Peter,</p>
Let me know and show me the bellcrank once the engine is installed. I am currently using a standard servo for the cable and sleeve throttle to overcome the 90 degree friction. i am also usign a standard servo for rudder control and two micro servos for the cyclic. </p>
</p>
If bellcrank is better, i might be able to save some weight to convert the throttle servo into a micro one as well.
</p>
thanks for the 4mm music wire!</p>
</p>
Cheers!</p>
Lawrence</p>
</p>
PS: I have currently purchased 11.1 V lipo for my old kalt baron whisper electric heli. It was powered by a 8.4V nicad. The new performance with the installed brushless motor is brilliant! from a 'struggling' hover with the heavy nicad, it turned into an 'eager' fast flyer now!! Whooohooo</p>
</p>
