RCU Forums - View Single Post - FLy Eagle Jet Models
Old 05-28-2009 | 05:39 AM
  #1723
CPing's Avatar
CPing
Default RE: FLy Eagle Jet Models
ORIGINAL: funflyerf4
Well two years later the F-16 flew.And the wheels and doors worked after new air cylinders were installed and valves and tubeing.The plane is the 1/8 first verson with a p-70 in it.The plane came out at 21.1 lbs. dry.The cg is at 152mm back and the throughs were what FE.recommended.The flight lasted 5 min with fuel almost full in the 2 main tanks the first 16 oz. over the intake is used first.I bent the front pin on landing and drilled it out to a 1/4 pin size.The plane is ready to go again.
I'd like to know how you liked it as well.
Also would like your thoughts on having the CG at 152. Seems most are using 140.
Craig
