RE: 41 Falcon cat build
Currently building the Falcon and thinking about using the 32% CG, like the way the boat in the video ran. If I need to put a small foil on the nose wan't be a big deal.
Using a skeged strut from accu-tech,and rudder from accu-tech.
Should I use only the 5/16 tude or both 11/32 and 5/16, just the 11/32 where it exits the hull?
Thanks Randy
