RE: Need a little Ryobi help
Sounds like the crank fit in the bearing is a little loose. This is a bit strange, as usually on Ryobis they are a bit too tight.</p>
You will probably have to machine a groove in the crankshaft for a circlip to prevent the crank from "walking". Be careful, because if it walks back far enough it is going to smack the reed valve stop and make a mess....</p>
AV8TOR</p>
