Intro Pattern Plane & Engine Combo
I'm considering building a pattern-oriented plane. My primary goal is to improve my flying skills thru pattern flying. Several club members are helping to train other club members using the IMACBasic patterns. I'm not sure whether I will or won't compete.
My current inventory includes a SIGSomethin' Extra kit w/ OS46AX (fav), SIG4Star60 kit w/ Saito 91, GPBig Stik 40 ARF w/ Saito 82, SIGHog Bipe kit (not covered yet) w/ Saito 100 and a (used) ShowTime 50 ARF set up for the Saito 82. These are all consistent with my plan of keeping my inventory in the glow 40 - 60 range. I tried a Avenger combat plane with a OS25FX (tuned pipe) that would turn 18K - not the style of flying that I want to do. Also, I'm not inclined to migrate to gas or electricity any time soon.
I really like the style of the Chaos (we have several at the field) - seems a bit old school and I find that appealing. I also like the concept of a tuned pipe application. (A club member is selling a Rossi 61 w/ tuned pipe.) Whatever I do, it needs to put a smile on my face and easily fit in the back of the old Volvo stationwagon.
Here's what I have in mind:Bridi Killer Chaos 60 with a Rossi .61 with a tuned pipe. I fly at altitude (5500+). The est. weight is 6.5 lbs. The Bridi XLTis also an option but it is more focused in its intent and its est. weight is 7.5 to 8.5 lbs. I do like the XLT's use of a faux canopy to shroud the exhaust (requires an engine w/ rear exhaust).
Rx will be Spektrum 2.4, battery NiMH 1500 6.0v., surface servos Spektrum DS821 digital (75+ torque), thro servo HS425HB, switch MPI combo. Controls will use CFtubes w/ ball joints at servo & Robart ball joint horns on the surfaces.
1) What's good-n-bad about the Killer Chaos? Highly recommended alternatives w/ reasons?
2) What's good-n-bad about the Rossi .61? Highly recommended alternatives w/ reasons?
Thanks so much for your input!
