ORIGINAL: brancoli
Hi Ian,
Any pictures for Saito FG20 installed?
I have a FG20 on the bench, seems this SD is a good choice ...
Do you installed inverted?
Branco
Well bad news , flying it yesterday and it went off tune a bit , so landed and noticed the needle valve extension shaking more than usual....any way whats happened is that because I used the NYLON engine mount that came with the kit , the mount for the carby and inlet pipe has broken from the vibes....a piece has broken out of the backplate.....very THIN AND WEAK with all that pumper gas carby hanging out there...
My advise is to use ONLY A METAL ENGINE MOUNT , the heavier the better , I will be taking it to the importers and claiming under warrenty
Ian
