RE: YS-170CDI Flight Report
That isn't too far off. I'm using around 160 mah for both surfaces and CDI with the new Hyde LR 85 mount. That is his Merle's new mount with the limiters built in. On the AR80 I was using previously I was using between 200-225 for the same flight period. I really like the way the new mount works. The idle is very nice as the engine is basically hard mounted at idle, and as soon as you advance the throttle it slides off the limiters and gives you the full vibration reduction.</p>
</p>
Arch</p>
</p>
