ORIGINAL: Campgems
I've got to add a however. I wouldn't use the EZ conectors on ailerons, rudder, or elevator on any plane above a 40 size, and maybe some of the 40 Size rockets migh need a more secure linkage.
Don.
I just used them on my new Ultra Sport 60 with a 75AX in the nose. This is not only a rocketship, but it is also my new "Baby". I have complete faith in EZ Connectors. Just be sure to tighten the screw. You need to hold the brass barrel with a plier as you tighten. Just using the pushrod to hold it is not strong enough (And use threadlock)
