110s Tappet adjustment
Any tips on adusting the tappets? Never done this before. Iknow the recommended range - Iassume both valves should be adjusted to the same gap thickness, and that the adjustment is done with the valve is closed.
Is there an advantage to a smaller or larger gap? Or should Ijust go right smack in the middle?
Thanks.
