RE: Z bend
If you ask me, they are cheap enough to just use only once. What's the gamble? Use twice and chance a critical control surface becomming uncontrollable? </p>
I have a small box full of the darned things. I just grab one and use it. If I have to take the thing apart, I throw the first one away and use a new one. Cheap insurance.</p>
I used Z bends for a very short time but found that the Z bend was not perpendicular and, to my observation, may cause a bit of a bind in the linkage to the control. For the most part, they went on the servo arm. A possibility is that they wear into the servo arm hole, enlarging it a bit, which causes slop. Not detremental, but it could create poor resolution at best, and flutter at worst. </p>
Again, this is just my opinion and my justification to not use them or to use something different, like a 90 bend with the EZ link connectors I mentioned in my prevoius post.</p>
CGr.</p>
</p>
