RCU Forums - View Single Post - Powerbox RRS Question
Old 05-30-2009 | 05:36 AM
olnico's Avatar
olnico
Default RE: Powerbox RRS Question
ORIGINAL: Zack Morris
Hi,
I mean it does measure the strength of the signal it receives. It can be valid but weaker. On the display are the signal strength in % for each receiver.If one receiver is 100% and theone it is using drops to 95%, it willswitch to the 100% one.
If you have a power failure on a receiver you would get 0% signal so it would switch to the other receiver. Putting it simply, If both are working fine but one has a weaker signal than the other for whatever reason, it switches to the stronger signal.
In a failsafe condition, the receiver is still able to send a failsafe signal. With the RRS, you set a spare channel to do this. The receiver goes to FS and the channel you selected for FS switches over and this is the FS signal the RRS detects and will automatically switch to the other receiver.
Does this answer your question?
</p>
Hello Zack,
Sorry to tell you this but you are wrong in your statement.
This is the common mis-conception about the RSS system, and is mostly due to the fact that the user manual is not very well written on that respect.
The system has no way to know the "strength" of the reception signal ( except if you use a PPM receiver ).
So for PCM and 2.4Ghz systems you need to program the transmitter ( "Smartsafe" for JR/Spektrum ) to send a FS signal to a specific channel that the RSS unit will see.
This channel has to be plugged to the FS input for each side.
Refer to this thread for a more detailed procedure:
http://www.rcuniverse.com/forum/m_8038701/tm.htm
I have also writen a complete "how to" article for RCJI that will publish along with the new Royal/Spektrum unit review.
