RCU Forums - View Single Post - big gap
Thread: big gap
Old 05-30-2009 | 11:50 AM
flaminheli
Default RE: big gap
I would not even worry about the gap. If there are two pegs in the leading edge and one or two bolts holding the trailing edge to the fuselage and both wing tips are perpendicular to the ground when the wing is bolted up then it should not effect flight performance at all. If it bothers you then use the methods mentioned above.
