RE: 50cc Sukhette Build Thread, now in progress!!
Many methods to use. Here's mine.
5 flips with ignition off, throttle full open and choke closed.
Open choke and a little gas falls out of the carb. Then close throttle to idle and flip 3-5 times.
Ignition on and it starts after a couple flips.
Alot of folks just keep it idle and choke closed with ignition on. Motor starts then dies due to choke. Then open choke and restart. Find what your motor likes and stick with it.
Just remember that every flip of the prop has the potential to be a start! Treat it that way and you'll keep your fingers on your hand.
