I had similar problems on a gas engine that was sucking large quantities of air through a pin hole in my gas line filter. Are you sure your lines are good? Also, a freind had similar problems caused by his spark plug gap set way to small. The spark was too weak and the plug just got wet and fouled. When we opened up the gap to the recommended setting, the engine purred like a kitten with fresh milk!
Good luck!
