RE: Ultracote & Monocote
hi monocoat is a bit more shinny- ( plastic looking ) ultracoat looks more like a paint job- and will go around compound curves much better -ex.those big round fusesif having a problem with the heat of the day-making wrinklesput a pin hole or two in each open bay of a wing- i do like to work with ultra coat more i think the color of the monocoat you are using seems to effect the way it works-(white harder than black )-the monocoats that have lasted me years without any lifting are the transparent colors- ( 20 years -no lifting )but only use them on the top side of a wing or you will have a problem seeing the plane clearly in the air -with the light coming thru the wing-the transparents are also lighter -have had my best experience with the transparent monocoats staying put of all coverings i have ever used
