RCU Forums - View Single Post - Front Wheel Toe-In or Toe-out
Old 05-30-2009 | 03:33 PM
Tree1
Default RE: Front Wheel Toe-In or Toe-out
ORIGINAL: breezerboat
is there any way (trick) to measure toe out easily. Mine really looks like it may be more than 2 degrees.
Yup..its called a "Set-up Sation". If you can dish out the cash for one right now, you can use a leveler. Ihave a 2 foot leveler and I use to put the leveler beside the rig touching the front and rear tires simultaneously. I would adjust the turnbuckles so that the front tires were flush against the leveler.
