RCU Forums - View Single Post - Muffler Pressure Needed?
Old 05-30-2009 | 05:27 PM
wcmorrison
Default RE: Muffler Pressure Needed?
If the tank is properly mounted and close to the engine you might get away without using pressure from the muffler set up.  Or you can add a Perry oscillating pump and that will do the trick for sure.  </p>
Cheers,</p>
Chip</p>
