RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 05-30-2009 | 10:37 PM
  #1171
handglider's Avatar
handglider
My Feedback: (23)
Default RE: Black Magic VF3 Build Thread
Hi Chris,
1. I've attached the drawing I created for theanhedralroot rib that I am running, Iam fairly sure this is the production ribs that Mike is shipping. The tube is below the centerline so becarefulwhen you glue those as you will have left and right sides.. the best thing to do is trial fit before you glue. (download and save as .pdf)
2. the stab rod adjuster only needs to extend from about 1/2 to 3/4 inches into the stab. Mine are less than 1/2 inch to save that extra gram.
3. It might be best to send the engine back to Richard at YS for the check up if your worried about doing the work yourself, at least it would becoveredunder his servicewarranty.
good luck and looking forward to seeing the plane.
dean
<br type="_moz" />
File Type: txt
