RE: First Scratch Build
Iadded some tri-stock in between the braces on the wingtips to strengthen them a bit. Ialso glued a piece of dowel into the center section of the wing, where the building pins were located. You can see the plywood plate that will reinforce the bolt holes.
Istill need to build the servo supports and the gizmo that holds down the front of the wing. Iam going to wait until the fuse is partially assembled to fit that together.
