RCU Forums - View Single Post - RCV120SP mounting options
Old 05-31-2009 | 06:39 AM
ktcanuck
Default RCV120SP mounting options
I believe someone asked this before but it wasn't fully answered. I am about to mount one in a TopFlite Bonanza. The Bonanza nosewheel is offset to starboard. I would like the exhaust exit on the port side so I have more room to route the exhaust internally without conflicting with the nosewheel mount or cowl.
I guess the first observation is about that crankcase vent. It looks like it must be mounted close to the bottom so oil doesn't build up in the crankcase. What tolerance can be applied to the mounted orientation of the crankcase vent?
Second question is whether you can separate the cylinder assembly from the crankcase and rotate it 180 degrees so the exhaust is on the right, carb on the top and vent on the bottom - all looking from the front. Can the timing be maintained?
Answers much appreciated soonest - I am at engine mount stage right now!
Keith
