RE: Can't get plane off ground
I know you have probably heard this a hundred times but here goes again:: It sounds like you are new at this game and if you can you should find someone local that knows planes / engines to help you. Not only for your safety but also your pocket book.</p>
To start with here, you need to write more information about what's happening and what you are doing. Does it run OK, is it going the right direction. are yoiu able to taxi, are the controls going the right direction etc.etc..
A 10 x 6 prop should pull the plane if it calls for a 40 - 46 eng. and it's adjusted right. </p>
Now if it will taxi but won't lift off, are your controls gouing the right way? If the elevator is backwards, you won't get off and probably if you did there is a good chance your ailerons are backwards and that means a sure crash..</p>
I don't mean to sound mean but it does sound like you should get some assistance before you waste your money by crashing. If you crash you may give up and we want you to stick around. By the way if you are new, that plane is not for beginners..</p>
ENJOY !!! RED </p>
</p>
</p>
</p>
</p>
