RCU Forums - View Single Post - Building The Arrow
Old 05-31-2009 | 09:27 PM
Johnkpap's Avatar
Johnkpap
Default RE: Building The Arrow
Ok this is what I have worked out
My OS61 V will fit fine but If I use the pump it will be a tight fit >> not alot of room !!! , I may have to use just presure feed from the pipe,
I have a Tuned pipe that is a exact fit even though the back is no the Squared off type used on the origional model
AMACheadder will also fit ( I will need to cut it down)
My Rohm retracts will also fit, this front one looks just the job.
I also have a Fuel tank that will fit as per the plan.
Now all I have to do is run the OS61 On the pipe and make sure the fuel pump works without the return as I only have a 7M or a 7D carb
Then its time to start cutting wood.
Thanks for the support
Johnkpap
