RCU Forums - View Single Post - Can't get plane off ground
Old 05-31-2009 | 10:25 PM
Toxik
Default RE: Can't get plane off ground
Thanks guys
The CG is something I haven't checked. The elevator servo is correct. As I go down the field, I tried pushing up to see if I had the servo reversed but it did a hard nose dive. I was wondering about the prop if I had it backwards or not but it seems that it was correct with the letters facing out.
I don't know what the rpms are at so I'm not sure if the prop is spinning fast enough. The field is pretty big so I don't think that should be an issue. There were a couple of times when the plane came a couple of feet off the ground but that was it. I checked all the controls against the simmulator and see they are going the right direction. I suspect the problem has to be poor tuning or to weak a motor for the plane size even though the plane manual states that a .40 or .46 is the right size for theplane. I'll head down the the hobby store this week with the plane and see what they say.
As far as flight experience, there isn't a lot other than realflight g4.5
Cheers</p>
