RE: Eric is THE MAN
georbeckha</p>
Twist the glow plug leads around each other that will help. A poor ground at the glow plug can cause the high rpm reading too. Did you extend the glow plug leads? Using wire that is too light a gauge will make it worse. Not really a big deal if the turbine lights off and starts ok. Rpm readings will return to normal as soon as the ECU sees ignition (heat) and turns off the glow plug.</p>
