RCU Forums - View Single Post - 12FG Multiengine Throttle Cut and Idle Down?
Old 06-01-2009 | 09:21 AM
Bax
Default RE: 12FG Multiengine Throttle Cut and Idle Down?
The Throttle-cut and Idle-Down functions only work on the Throttle channel.  Throttle2 and Throttle3 would not be affected.  The easiest way is to just use three instances of "Throttle".  You'll be able to set up the ATV's independently, as well.
