RCU Forums - View Single Post - 2.4Ghz - Is it really ready for Hobby use ?
Old 06-01-2009 | 10:50 AM
Duncan's Avatar
Duncan
Default RE: 2.4Ghz - Is it really ready for Hobby use ?
Xantos,
sorry that you have lost your model, I had the issue with the retracts doing their own thing when switching on as you stated
"The point is - the 2.4 system seems to have too many quirks and bugs most of which are encountered during setup i.e while binding or after binding some systems will cycle the gear on powering up or a bound system will require to be recycled"
I found the reason was operator error (ie Me ). If the power is switched off with the retracts up (i did this to load the model in my car) the clever spekky system remembers this and it becomes the position for every power up. To undo this, power on, cycle your gear a couple of times, finishing in the down position and then power off.
Yes it is a bit of a quirk, but like everything new, once your used to it, it's a non event.
Duncan
