RCU Forums - View Single Post - adding weight to a cpv3
Old 06-01-2009 | 08:16 PM
osterizer
Default RE: adding weight to a cpv3
All that adding weight will do is make it more sluggish and use more power. The heli leans to the side to counteract the thrust from the tail rotor, which tends to push the heli to the left if you hold it level. You'll get used to it, but if it's causing that much trouble, you might do well to get training gear for the heli until you've become accustomed to it.</p>
</p>
