RCU Forums - View Single Post - Thank you!
Thread: Thank you!
Old 06-01-2009 | 08:55 PM
GaryHarris's Avatar
GaryHarris
Default RE: Thank you!
ORIGINAL: qwertypemdas
Well I've decided to do the bolt on wing mod just because I love building. I have plenty of extra covering and don't mind spending 10-20 hours on it. I don't have a tap so I'll just use blind nuts. Some pictures would be good. (maybe a new thread) My biggest concern is getting the front end to seat down tight.
It won't take that long. Just drill two 1/4" holes through the leading edge and add an extra support near the main spar. Use 30 minute epoxy and all is good. For the rear, do it the same as the arf with 1/4-20x 1 1/2" nylon bolts and maybe add an extralayer of thin ply on top of the trailing edge on the rear where the bolts go through. Ill post pics tommarow of how the arf was done.
