RE: Ultracote & Monocote
Verry true minnflyer!!.....
The MK, one you iron down the wrinkle you are screwed......
I have learned to not ever touch the wrinkle with a iron....only a heat gun, or just use the heat of a iron...or it will stick....
Iron down the edges first, and then heat the middle.....but do not secure or have the covering adheare to the middle until it is absolutily neccissary.
