RCU Forums - View Single Post - large brushless cat project
Old 06-02-2009 | 11:13 AM
  #48
Stokes's Avatar
Stokes
Default RE: large brushless cat project
hey Nor,
yes I'm using graupner props. 51mm for 4s and 47mm for higher voltages. I will use them to try and find the fastest/most reliable combination, then change to octuras with the same diameter. I'll take a few pics later of the water pickups, still need to epoxy them lightly from the bottom. I haven't changed the bearings yet, will order a set with my next shipment from OSE. In the meantime i started another project (waiting for the epoxy to dry)...how are you getting along with your build? any pics?
A
