ORIGINAL: weezle
F5
I have the 110 alpha and the break in procedure is the same as your .81 alpha. First completely close the high speed needle and then open it 3 or 4 turns ( you might want to double check the manual on this) then start your motor. Let it warm up before you start leaning it, I let mine warm up 4 or 5 minutes at low rpm's (3000 to 4000). Then I did just as the manual states. I opened the throttle all the way up and leaned high speed needle for near max rpm's (for a few seconds only) then I richened 1 turn. I did this for the first 2 tanks. My motor currently has one flight its very strong transition is very smooth
thanks Weezle, and how long did you wait on every max rpms/lean process.
