RCU Forums - View Single Post - AIRPLANE OR HELLI ENGINE?
Old 06-02-2009 | 04:14 PM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: AIRPLANE OR HELLI ENGINE?
The carbs are optimized for mid range in many cases
The heads are bigger for cooling
The crankshaft is shorter for mounting a clutch/fan (not the crankcase, the crankcase is identical)
The nusance is getting a prop drive plate, spinner back plate, prop, washer, and prop nut on the short crankshaft.  Everything else is pretty much the same.
