RCU Forums - View Single Post - Kaos mod problem!
Old 07-09-2003 | 11:11 PM
Fubar-One's Avatar
Fubar-One
Default Re: Re: Kaos mod problem!
Originally posted by wakewatcher
I assume you got your servo wire fished. I'm just starting my Kaos and was thinking about doing the same thing. Was wondering what you did. I assume it wasn't two servos side by side in the fuse. (Probably wouldn't fit.) Was it a trick to beef up the wing to hold the servos? How does it fly? Are you using Flaperons or coupled elevater/ailerons? I was thinking of putting a saito 56 or 72 in the front end (if the prop will clear) and also thought about putting the elevator and rudder servos near the tail feathers rather than using lead back there. Opinions?
I used two HS-225 servos side by side for my dual ailerons. Fits in the Kaos fuse with no problems. Works fine.
