Got it.I forgot about the fact it's in halves. Thanks.
ORIGINAL: opjose
Why bother?
That is more complicated that it needs to be.
Look at that picture you posted from my battery pack.
There was already a hole in the back for something, at the junction I believe...
But just use a small dremel sanding drum at the edge of the back, to create two semi-circles.
Do it so that when you put the bottom cover on, you end up with a whole circle.
Then just feed the wire through the circle BEFORE you put the bottom on.
Simple, and there is NO cutting of the Tamiya connectors involved.
