RE: SIG KADET SR FLOAT REC.
The attachment of my Senior Kadet should give you an idea of where to mount the floats. They are 48 inches long, made from Sullivan stock foam and covered with fiberglass and epoxy. The tip is three inches in front of the spinner. They added about 3.5 pounds, making about 11 pounds total weight. It's a great flying plane, with several hundred flights since 1999. Good luck.
HughO
