RCU Forums - View Single Post - OS 91 WITH PUMP
Old 06-03-2009 | 12:32 AM
Kostas1's Avatar
Kostas1
Default RE: OS 91 WITH PUMP
ORIGINAL: barzini
I have an OS91with pump that suddenly lost some power. I checked the valves and they are within spec. I noticed that when i turn the high speed needle all the way in until it seats gently, The engine still runs?? I have 2 OS 120 with pump and they are powerful trouble free engines. This one has me puzzled? Any ideas.
Thanks, Barzini
Barzini,
i am not the best guy to give you advice,but i will try.
Loss of power may be visible if you lost compression,
due to an overheated run,
and destroyed the valve seals,so they don't sit flush on the burning chamber's head.
Assuming that all settings stayed the same before and after...
But,
yes maybe you should go and ask Bax!
I reallly like to know what caused that,because it's not that of a cheap engine
Konstantinos
Greece
