RE: 12FG Multiengine Throttle Cut and Idle Down?
Bax,
You mention ATV, but 12 FG uses AFR to adjust throw. Is there an ATV adjustment somewhere that I am not aware of?
When I use 3 instances of Throttle, only one AFR is provided. The throttle AFR affects all 3 channels assigned to it equally. There is no way to set curves for each channel individually. How do I adjust each throttle response curve individually??
By the way, what does "AFR" stand for???
Bryan
