RCU Forums - View Single Post - EI modules
Thread: EI modules
Old 06-03-2009 | 10:06 AM
arobatx
Default RE: EI modules
....to use on what?  If you are replacing an EI, some are swappable with the RCEXL ignition, and some are not.  Some hall sensors need exposure to one side of a magnet, or the other pending the brand as well.  Timing can also be an issue pending what you are doing with it.  I would suggest giving as much information as you can, about what you intend to do with the ignition, and there will be plenty of help here to guide you along.
I might also recommend for very good quality ignition Q and A....contact www.CH-ignitions.com
