Andy,
where does one pick up those magnets. I've looked around but they all seem to be huge! How about some button sized magnets like those used in ARF's?
Kevin,
7 lbs sounds great. Iassume that is an unfinished AUW. Did you actually pick up skins that are comercially spliced (by Balsa USA) to cover the width of the wing or did you make up your skins? I've always been curious about the quality of the commercially bonded ones but they always seem a little dear on the pocket. As a result, I've just made my own.
I assume that Don from Eureka is cutting full width cores including ailerons which are cut from the core? (I know he is on some other kits) That makes for a nice wing & stab.
Is your BEC capable of outputting at two different voltage levels (
[email protected] &
[email protected])? Nice, I'll have to look into that one.
David.
