RCU Forums - View Single Post - Flap Servo Travel Setting??
Old 06-04-2009 | 01:52 AM
digitech
My Feedback: (10)
Default RE: Flap Servo Travel Setting??
ORIGINAL: SinCityJets
When you set up your flaps, do you use a travel setting of +100 (up) to -100 (down) (the figures do not have to be 100%, but are you using the full range of the servo travel), or are you at "0" at up and just using from 0 - 100 (down).
In other words, are you using the full servo travel, or half the servo travel for your flaps?
Thanks for the input.
Chad
always use the full servo travel .
if you use half you only have half the strenght!
set to 100% flap 0 and make your linkage from there.
