RE: Flap Servo Travel Setting??
What Sandor means is use as much of the available servo travel as you can & vary the horn length & hole position on the servo to get close to the needed flap movement.
It's the same as short or long servo arms, it's easier to stall a servo if it has long arms on it so keep them short.
Likewise it's easier to move a control surface with longer horns on them so keep them long.
By increasing the servo travel you can make the servo arms shorter & the flap horns longer. - John.
