RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 06-04-2009 | 02:08 PM
  #10722
theradioflyer's Avatar
theradioflyer
Default RE: Wheeeeeeee.......... Blade CP!
Looky, even your stalemate is beyond my skills
JPEE, are you running the same Tx for all 400's or a different one for each?
I think I cleared up all of my glitches and tail hold problems I've had. The HBKII would glitch and the RPMs would drop significantly. I watched Finless's video on the GY401 set-up and found that I had screwed stuff up big time. Some where I had read to remove the yellow wire fron the rx and leave it out..... wrong, I plugged it back in on both birds. I also had my rates set for standard mode not HH. I had thought that with the yellow wire out it defaulted to HH,( telebee does this I think.) With a new mechanical centering and reprogramming I'm back to HH buisiness. One flight on the SA proved perfect tail hold, now to perfect the gain. One flight on the HBKII no glitch but I need new batteries.
Blessings,
Jay
