Poulan 33cc chainsaw conversion
If you are going to use the original ignition, you'll want to keep the flywheel. But it can be machined down or the fins cut down flush but it shgould be balanced.
If you use a battery ignition, the flywheel will have to be replaced by a magnet hub.
Jim
