RCU Forums - View Single Post - First Scratch Build
Old 06-05-2009 | 01:01 PM
  #38
mclina's Avatar
mclina
Default RE: First Scratch Build
This is the first test fit of the wing. The saddle is a pretty good fit. Iam going to make up some kind of tab below the LEof the wing to key into F-2. Iwill probably laminate two L shaped pieces of 1/8" ply on either side of the center ribs, with a spacer in the middle toaccount for the rib thickness.
Iam waiting toinstall the rear pushrod tubes before Iclose up the top of the fuse.
ID:	1212321   Click image for larger version
ID:	1212322   Click image for larger version
