RE: STAR WARS Tie-Fighter Interceptor Build?
Hey thanks! The detail was pretty easy, I just used black spray paint and my finger. I sprayed on a scrap piece of foam and let it puddle up. Then dipped finger and smeared it across. Cheap and easy haha.
As for the CG. Well it was weird finding it. I see on others they measure from the very tip of the boat and go back from there. I would have thought you would measure from the LE of the wing. This is kind of what I ended up going with.
But here is two measurements:
4 1/4 from the LE
9 1/4 from the very tip of the entire boat which is the sponsoons or pontoons not sure what to call those.
Hope that helps
