90 degree elbows
CHECK OUT CENTRAL HOBBIES TETRA FUEL ELBOWS ON THEIR WEBSITE. I USE TWO 90 DEG. ELBOWS OUTSIDE THE COWL WITH A FILTER ATTACHED TO FUEL TUBING BETWEEN THE TWO. ONE SIDE GOES TO THE TANK FOR FUELING AND THE OTHERSIDE TO THE CARB. YOU JUST FUEL UP AND CONNECT THE OUTSIDE LINE BACK TOGETHER - NO FLOODING. TRHIS IS A $5 SOLUTION.
